Hi ghoulpn. Welcome to the forum. When you "hear the solenoid click" do you mean a kind of loud clunk from the starter or a light click from the starter relay? If you're hearing the starter solenoid engage, this is a common symptom of worn solenoid contacts, but this isn't a real common problem with GM starters. Since you've gone through so many already, I think I'd be looking closer at the cables.
This will take a little work, but the place to start is by attaching a jumper wire to the starter motor's heavy battery cable, then attach the other end to a test light that's grounded to the battery negative post. The light will dim just a little during cranking, but if it goes out when the solenoid engages, there is a corroded spot somewhere in the positive cable. If the light stays bright, move the test light's ground clip to the engine. If the light goes out now during solenoid engagement, the negative battery cable has a bad spot.
If the test light stays bright, move the clip lead to the braided cable from the starter motor that's bolted to the other large solenoid terminal. The light should be bright when the solenoid engages. If it is not, the solenoid contacts are worn.
Caradiodoc
SPONSORED LINKS
Monday, April 19th, 2010 AT 5:57 PM
