Welcome, the temp switch is a ground for the gage, the more continuity to ground, the higher the gage reading. The hotter the coolant the less resistance. Possibilities, the gage itself has a problem-- the wiring circuit has a fault-- or the switch has a problem. On the 3.1 and 3.4 the switch is located on backside of engine, driver side, one wire connector, dark green. Unplug it, see if gage acts any differently?
SPONSORED LINKS
Thursday, February 4th, 2010 AT 10:24 AM
