Hi there,
there are a number of tests that can be done to see if the head or gasket is causing a problem, the best test is called a head check, this is a simple chemical test to determine if there is exhaust gasses in the cooling system, if so then you do have a gasket problem.
Mark (mhpautos)
SPONSORED LINKS
Sunday, July 25th, 2010 AT 10:39 PM
