1990 Pontiac Grand Prix COOLING FANS
KVACEN
  • 1990 PONTIAC GRAND PRIX
Engine Cooling problem
1990 Pontiac Grand Prix Front Wheel Drive Manual
why wont my cooling fans come on?
Friday, May 14th, 2010 AT 10:18 AM
INTERNETMECHANIC
  • 700 POSTS
Check for any applicable trouble codes. Check the circuits to and from the fan relay. If you turn on the ac does the fan come on? If you unplug the cts, (coolant temp sensor), does the fan run? I wouldn't replace anything without trying to track the problem. What is litre size of engine? Did you check applicable fuses?
Friday, May 14th, 2010 AT 11:10 AM
