Car starts but in a second or two it stops. When it is warm and running the rad cooling fans don't come on. If I disconnect the engine temperature sensor, cold starting is good and coolong fans run. Engine light is on and two engine codes show up PO102 and P0118. Can you help?
SPONSORED LINKS
Friday, May 15th, 2009 AT 7:49 AM
