1963 Pontiac Grand Prix points
MICHAELSHULTS
  • 1963 PONTIAC GRAND PRIX
Engine Mechanical problem
1963 Pontiac Grand Prix V8 Two Wheel Drive Manual
How do I set the points
Sunday, July 13th, 2008 AT 12:36 PM
DOCFIXIT
  • 18,828 POSTS
Loosen dist. After new points in so the cam is opening points. There is a allen screw you turn to adj. Set.017 to.019 feeler gague, Return dist to previous position leave loose. Attach dwell meter to coil neg. And ground. Start adj. Point gap until you read 32 deg then set timing.
Sunday, July 13th, 2008 AT 12:56 PM
