A few days ago I had a problem with my car stalling out on me on the highway. It started back up immediately and did the exact same thing about 30 miles later. I replaced the fuel filter and put fuel injector in the tank and it ran fine for a couple of days, then the problem occurred again and far more frequently. I can barely get the car to run a couple of miles, and then it cuts off. I’m still getting power to everything; the power panel still works fine, I’m just losing power to the engine. The car will start back up after a few minutes, then goes through the same thing. Any suggestions as to what may be causing this problem would be appreciated. I noticed a few other posts with similar problems, but I noticed there were panel light problems, which I am not experiencing.
Jan 9, 2007 at 4:24 AM
