2000 Pontiac Grand Am engine stalls while driving
TRISHY2585
  • 2000 PONTIAC GRAND AM
  • 4 CYL
  • 139,000 MILES
My engine stalls while driving. I've had the fuel filter and pump replaced. It was only doing it when it was under 1/2 a tank, then it was 3/4 a tank now it stalls all the time while I am driving. When it stalls the trac off light will also come on. Once when it got down to almost half a tank it idled so low that it died while I was trying to go. I was in a parking lot thankfully. I have takin it to the dealer and other people no one can figure it out, so I need so more ideas.
Sunday, February 1st, 2009 AT 11:35 PM
SAWMASTER88
  • 38 POSTS
Have you checked the fuel injectors, they may be very dirty or could be failing. One other thought that I can come up with is that your Idle Air Control Valve (IACV) could be failing or has failed. Hope this helps. Good Luck
Friday, February 6th, 2009 AT 1:16 AM
