2003 Pontiac Grand Am Poor Acceleration
NIKIYA1981
Hello, I am new to the forum, Hi everyone! I own a 2003 Pontiac Grand Am GT with 30940 miles and just today when I took my car out of park, it was hard to accelerate and go over 35 without pressing the pedal to the floor. Any info on this?
Sep 22, 2006 at 8:35 AM
PJ(GTO)
  • 36 POSTS
What sounds did it make?
Was there any smoke and if so what color?
Oct 13, 2006 at 7:03 PM
NIKIYA1981
Thanks for your reply. No, there was no smell, sound nor any smoke. It just takes a little more force to make the car go above 50mph.
Oct 16, 2006 at 7:55 AM
LSUSSEL
  • 252 POSTS
I suggest you run down your tank of gas.. and fill up with a higher grade gas. I only use Shell.. I dont know where you live but if you have a Shell near you.. take the time to fill up on the highest grade and go to your local auto parts store and buy a bottle of engine cleaner that cleans the engine of sluge and that sort of thing.. try that.. and if that doesnt work.. it could be something more serious.
Nov 3, 2006 at 3:39 PM
VEGASMSTRJ
  • 50 POSTS
also you might want to look into the fuel filter. could be clogged and the engine cant get enough fuel.
Nov 13, 2006 at 10:52 AM
Suggested Repair
Use a tank of higher-grade fuel and an engine or fuel-system cleaner, and inspect or replace a possibly clogged fuel filter. If acceleration does not improve, have the fuel system checked further.
Conversation Summary
The owner of a 2003 Pontiac Grand Am GT reported poor acceleration, needing the pedal pressed hard to exceed about 35-50 mph, with no unusual noise, smell, or smoke. Suggestions were to try higher-grade fuel and an engine cleaner, and to check whether the fuel filter is clogged.
