Its not burning the gas (because of the misfire)
that`s why the smell of gas and Cat. Conv. Red hot
Check the ignition module.
Its "random misfire" right:P0300 Random/Multiple Cylinder Misfire Detected
which means that its not an especific cylinder.
Check that first.[/Quote:127f13761f] I finally found the problem the plastic casing that holds the leads to transmit sparl from the coils to the plugs was bad even though it visually looked brand new put a new one on and the car runs perfect now.
Friday, October 5th, 2007 AT 7:59 PM
