1990 Pontiac Grand Am Pinging
THE_HYDROXIDE_CHILD
  • 82 POSTS
Hello.. Any Advice Would Be Helpful.. lol the title pretty much sums it up... my car pings realy bad... ive changed the wires, plugs, air fliter, fuel fliter, and i even put in 93 octance gas and it stills pings like a rainstick.... i have a 1990 Pontiac Grand Am.. 2.5 L approx 170K miles... maybe thats it... sound like a head or valve problem or what??? im lost i even bought a new egr valve not to long ago cuz i heard that will cause that.... it pings mainly on black gravel roads... any other road is hardly noticable and when the car is sitting sitting still... it dont tick it just pings
Jan 21, 2007 at 11:40 AM
MMPRINCE3000
  • 133 POSTS
Wierd!
Check the timing, don't forget to ground the diagnostic terminal.
Could also be the timing gear ( I believe this engine uses a gear).
Heavy or constant pinging will cause engine damage.
Pinging occurs under load, almost never at idle and if it occured at idle it would be MUCH worse under load.
Are you sure you don't have a loose heat shield rattling that sounds like pinging.
Jan 26, 2007 at 9:28 AM
THE_HYDROXIDE_CHILD
  • 82 POSTS
naw my car doesnt have a heat shield... and on my harmonic balancer is has no timing marks so i dunno how... but its does it pings bad...
Jan 26, 2007 at 2:22 PM
Suggested Repair
Check ignition timing with the diagnostic terminal grounded, and inspect the timing gear. Confirm the noise is not a loose heat shield. Constant pinging under load can damage the engine.
Conversation Summary
A 1990 Pontiac Grand Am 2.5L with about 170,000 miles pings badly under load, especially on gravel roads, but not at idle. The owner already replaced the plugs, wires, air filter, fuel filter, and EGR valve and tried 93-octane fuel. The expert advised checking timing by grounding the diagnostic terminal, considering a worn timing gear, and ruling out a rattling heat shield. The owner said there is no heat shield and no timing marks on the harmonic balancer.
