1995 Pontiac Grand Am Overheating
LABLUEYES2977
I have a 1995 grand am quad 4 motor .... 4 door.... mileage is about 99thousand.......
the night before the temp gauge spikes the 280 mark.....and then when i took off the gauge went down for a few...then came up and rode at the middle mark(220)....when i would take foot off gas or slow down to a stop the temp gauge will rise back up to the 280 till i took off again.....
I've checked the oil and there is not water in it....there is nothing coming out the back of the tailpipe.........and i've checked and its not leaving a puddle..... what other choices do i possibly have to go with???
Thanks
Jun 17, 2007 at 8:17 AM
SC1 RACING
  • 117 POSTS
engine fan may not be working, coolant level could be low, water pump could be going out, or steel radiator pipe under car could have came into contact with something and bent.
Jun 27, 2007 at 6:09 AM
Suggested Repair
Check whether the engine cooling fan works, verify the coolant level, inspect the water pump, and look for a bent steel radiator pipe under the car.
Conversation Summary
The owner of a 1995 Pontiac Grand Am with a Quad 4 engine reports the temperature gauge spiking near 280, dropping while driving, and rising again at stops. No coolant in the oil, exhaust steam, or visible puddles were noted. The expert suggests checking the cooling fan, coolant level, water pump, and a steel radiator pipe that may be bent.
