1997 Pontiac Grand Am Overheating
ITSALOVEHATETHING
1997 Pontiac Grand Am SE 2.4Liter V6.
I've been struggling with an overheating problem with my car for a few years. Everytime I take it in the mechanic "pinpoints and repairs" the leak, only to have it overheat, presumably from lack of water, a few days later.
My latest repair involved a new radiator, thermostat, heater core (the previous one had..well....exploded.) and any hosing that looked questionable. Didn't work.
After my latest boiling over, I got air in my system. How can I tell? Well..everytime the car changes motion (stop, go, turn, etc) I can literally hear water sloshing around. For instance, a right turn will give off the sound of a water trickling from a left to right, resonating from just behind my dashboard.
Also, if the car starts to get hot, my heater will only blow cold air, if it suddenly goes to hot air (as it sometimes does.) the engine temp immediately drops.
I had the radiator flushed yesterday hoping to get the air out before the whole thing becomes vapor locked (as happened before all the repairs) but I still hear the "sloshing" and sure enough, my car boiled over on the way home.
Is there a chance that a part in my latest set of repairs is faulty, or do I need to just keep searching for this phantom water leak?
For the short term, how do I get the air out of my cooling system? The car was easy enough to maintain water-level-wise before the air got in, only needing a bit of water every 3 days or so.
Thanks in advance.
Apr 8, 2007 at 9:37 PM
2CARPRO JACK
  • 11,533 POSTS
Chewck the water pump, its on the bottom in the back of the engine, closest to the fire wall. Also have it chemical tested for a blown head gasket, could be a very tiny leak and that is why you dont see coolant leaks and a reason for the heater core exploding (they dont normally do that)
Apr 9, 2007 at 1:20 AM
Suggested Repair
Inspect the water pump at the rear bottom of the engine near the firewall, and have the cooling system chemical-tested for a small head-gasket leak that could explain hidden coolant loss and heater-core failure.
Conversation Summary
The owner of a 1997 Pontiac Grand Am reports repeated overheating after radiator, thermostat, heater core, and hose repairs. Coolant still disappears, air sloshes behind the dash, and heater output changes as the engine temperature changes. The expert advises checking the water pump and chemical-testing for a blown head gasket.
