1995 Pontiac Grand Am Overheating
PHILTHOMPSON1043
I own a 1995 Pontiac Grand Am with 120000 miles, it has a 3100 v6 in the car. I recently replaced the head gaskets, however having an overheating problem with the car. I replaced the water pump, radiator and the thermostat and I am still having the problem. I am getting no coolant in the oil, nor am I getting coolant running out of the exhaust. Could you give me ideas of what to check next. Car is running fine, it is just overheating.
Nov 3, 2007 at 12:18 PM
BLACKOP555
  • 10,386 POSTS
simple fix. seems youve done all the major work, next is to bleed the cooling system, there is porably a air bubble trapped in there causing improper cooling, make sure the fans are turning on also
Nov 3, 2007 at 12:40 PM
Suggested Repair
Bleed the cooling system to remove a trapped air bubble, and confirm the cooling fans turn on.
Conversation Summary
A 1995 Pontiac Grand Am with a 3.1L V6 overheats after the head gaskets, water pump, radiator, and thermostat were replaced. There is no coolant in the oil or exhaust, and the car otherwise runs fine. The expert suggests bleeding trapped air from the cooling system and verifying that the fans turn on.
