2002 Pontiac Grand Am Stall - Fuel Pump Module Fix
KATECAM7
I drive a 2002 Pontiac Grand Am SE with 60,000 miles. 4 cylinders. Yesterday it stalled while I was driving it and had to coast it off the road. I had it towed to a repair center and they said they had to replace the Fuel Injector Module and the Fuel Filter. With parts, labor, and tax they said it would cost me over $900. I'm just wondering if this is a reasonable estimate. Should I take it to the Pontiac dealer for a second opinion? How much does this normally cost? Thank you so much!
Aug 28, 2007 at 2:05 AM
2CARPRO JACK
  • 11,533 POSTS
Im guessing you mean the fuel pump module and filter. That estimate sounds about right. 500.00-600.00 for the module (be sure they use a A/C Delco module) filter and a couple hundred to r&r the tank and repalce the module assembly
Aug 28, 2007 at 5:39 AM
Suggested Repair
Confirm the shop means the fuel pump module and filter, not a fuel injector module. An estimate near $900 is reasonable: about $500–$600 for an AC Delco module, plus the filter and a couple hundred dollars to remove the tank and replace the module assembly.
Conversation Summary
The owner of a 2002 Pontiac Grand Am stalled while driving and was quoted over $900 to replace a fuel injector module and fuel filter. The expert said the shop likely means the fuel pump module and filter, and that the price is about right if an AC Delco module is used, covering parts and tank removal labor.
