1995 Pontiac Grand Am Running Rich
CITYGUY1155
I have 1995 Grand Am with a quad 4 engine. It has 110'000 miles on it. A few months ago I replaced the coils, plugs and the coil housing. It was running great. The other day it started to miss and run rough. I checked the plugs and they are burning black. You can also smell gas like it is loading up. IA few people told me it could be the egr valve or the pressure regulator putting to much fuel into the cylinders any ideas would be great.
Oct 9, 2007 at 10:37 AM
BMRFIXIT
  • 19,053 POSTS
[quote:79552f0a3d="cityguy1155"]I have 1995 Grand Am with a quad 4 engine. It has 110'000 miles on it. A few months ago I replaced the coils, plugs and the coil housing. It was running great. The other day it started to miss and run rough. I checked the plugs and they are burning black. You can also smell gas like it is loading up. IA few people told me it could be the egr valve or the pressure regulator putting to much fuel into the cylinders any ideas would be great.[/quote:79552f0a3d]
Good place to start
Fuel pressure regulator and the EGR
Put do you have check engine light on
that will help you pin point the area if you can get the codes
good luck
let us know
Oct 9, 2007 at 12:11 PM
Suggested Repair
Start by checking the fuel pressure regulator and EGR valve, and retrieve any check engine light codes to help pinpoint the rich misfire.
Conversation Summary
The owner of a 1995 Pontiac Grand Am with a Quad 4 engine reports a rough miss and rich running after recently replacing the coils, plugs, and coil housing. The plugs are burning black and there is a fuel smell. The expert recommends starting with the fuel pressure regulator and EGR valve and retrieving any trouble codes.
