2004 Pontiac Grand Am Stalls and wont start again.
ZEPPER
MEMBER
2004 PONTIAC GRAND AM
6 CYL
FWD
AUTOMATIC
109,000 MILES
Car stalls and then cranks and won't start. Then 30 minutes later will start but then stalls, etc.
Have replaced fuel lines, fuel pump, max air flow sensor. Out of ideas and almost out of money. Please help.
Thursday, October 14th, 2010 AT 4:45 PM
JDL
MECHANIC
When the problem occurs, have helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. I haven't looked your security system info?
SPONSORED LINKS
Thursday, July 30th, 2020 AT 4:59 PM
ZEPPER
MEMBER
I have requested that he check both those items now. Not sure how long it will take to get back to you as I am not in the same location as the car.
Thank you for your help!
Thursday, July 30th, 2020 AT 5:00 PM
ZEPPER
MEMBER
Ok yes it has spark and and he said the fuel pressure is good.
JDL
MECHANIC
Use a noid lite and check for injector pulse. You need to check for codes.
