electric windows?
75,000 MILES • 6 CYL • FWD • AUTOMATIC
JJDOVERFAMILY
Both the AC and electric windows are inoperable on my 2004 Grand Am. What could be causing this? Burnt fuse?
Jul 21, 2009 at 8:44 AM
  • 110,248 POSTS
That is where I would start. Did both stop working at the same time?
This guide can help
https://www.2carpros.com/articles/electric-window-repair
Jul 21, 2009 at 4:40 PM
JJDOVERFAMILY
Yes, both stopped working at the same time. I checked all the fuses and they are good. It is my understanding this could be tied into the ignition system. Anymore thoughts?
Jul 22, 2009 at 12:30 AM
  • 110,248 POSTS
They could be tied into the ignition, but I would think that other things would have stopped too.
Have you checked for fuses inder the hood in the power distribution box?
Jul 22, 2009 at 4:26 PM
USER309301
When it cools off they work
Jul 14, 2020 at 5:31 AM (Merged)
  • 110,248 POSTS
When they don't work, remove the door panel and check for power to the switch and the motor. Let me know what you find.
BLAZERMGB
My Drivers rear windowhas come off the runner. The moter still goes up & down but the window is loose in the door.
BLUELIGHTNIN6
  • 16,542 POSTS
you will need to remove the door panel to get a better view of exactly what has happened , the regulator may need replaced .
BLAZERMGB
[quote:61956265f7="blazermgb"]Interior problem
2003 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 96000 miles
My Drivers rear windowhas come off the runner. The moter still goes up & down but the window is loose in the door.[/quote:61956265f7]
I have the door panel off, the window runs up & down the vertical post but is not connected to the cable
BLUELIGHTNIN6
  • 16,542 POSTS
ok if the cable has broken then regulator needs replacing..
LUVMYMUMA2
Interior problem
2003 Pontiac Grand Am Front Wheel Drive Automatic
I need to change the sash clip on my driver side window and was just wondering how easy it would be to do myself. Is it pretty hard and or complicated or pretty quick and easy?
2CARPRO JACK
  • 11,533 POSTS
Once you get the door panel off to gain access it isnt that hard to do, trick is not to hurt the window when removing theold one, they are glued to the window.If you are patient and slowly work a razor blade between the two you can ge tit off there, then use some silicone and glue new one in place and roll window up for a day to let it dry in place
KJMCG121
I am trying to set my drivers side front window onto the track of the electric window system but can not figure it out. what is the trick to know about it.
Jul 14, 2020 at 5:32 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
Remove your door panel and locate the track/feet component the window came out of. Then, using urethane glue/sealant for auto glass, reaffix the window into the track/feet after thoroughly cleaning all parts of old adhesive. Be sure to carefully operate the window to check position before the adhesive sets. After installation is complete, leave the window closed and don't operate it for several days until sealant has set thoroughly. If you are not fairly confident of your ability to position the glass correctly in the track/feet, you may want to consider taking it to a professional glass repair shop.
Hope this helps..
Thanks for using 2carpros.com!
YANEISY13
About a month ago, I started my car, and none of the lights turned on, radio did not turn on and windows did not go up or down. The headlights do turn on manually, but nor the spedometor nor the gas gage works. So I messed around with it a little, if I turn on the car and then turn the key slightly everything turns on and windows work. but today it's just not working. On the other hand, the car is running fine. I would like to know if its just an electrical short? Is it fixed easily?
THANKS SO MUCH
SATURNTECH9
  • 30,869 POSTS
What model grand am do you have se or gt?Also two or four door?Sound's like it might just be your ignition switch since you moved it a little and every thing started working before.Let me know.
STELLA NOVELLA
The problem is fixed now, but I have never felt comfortable with the price I paid. My driver side power window "worked," but the left side of my window would collapse as the window came down. My brother took the door off to find that the left sash was broken. I think that's what the part is called, at least by the parts store, to describe the plastic pieces that keep the window in place. My brother fixed it, and it worked another 6 months before breaking again. I took it to a repair shop and told them this whole story. They ended up replacing the moter, regulator, and clips, which cost me about $200. I asked them to explain to me, before and after, why all this was needed; and their answers were smooth and confident but never satisfying to me. What do you think? Did I get ripped off? Any information would be very helpful. Thank you.
Jul 14, 2020 at 5:33 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
No, I don't thing so. Your repair didn't hold. That means there were other issues in there that were never found or addressed. That would explain the entire regulator being replaced. As for the motor, many "quality" regulators are only sold as a complete unit with a motor included so that may have been automatic or maybe they saw something weak in the motor. Remember, they don't repair things on the idea "I think it will work", they have to be thorough enough to know it's not coming back on them.
DCHEITEL
I have a 2002 Pontiac Grand Am
The driver side window has stopped working all of a sudden. No sign of previous binding and the operation has been very smooth.
I opened the window just fine and now it wont close
All other windows work so i know its isolated to the driver window. When holding the switch either in up or down positiion I hear a click after a few seconds indicating to me that the motor breaker is tripping and after a few seconds it does reset.
I want to know if I should be looking at the regulator for the window or the motor itself. Or could it just be stuck and if so, what is the best method to figure that out
Thanks
Jul 14, 2020 at 5:34 AM (Merged)
BOOTDOG
  • 665 POSTS
window motors can go either way, all of a sudden stop or slowly give you signs it's going bad. either way the regulator going to have to come out. hope the info helps
TAMBONE1970
I want to knoe the names of certain parts pertaininf to the pontiac grand am 2002 for the power window?
  • 75,988 POSTS
Windows and Glass Component Selection Repair Info Parts
& Labor
Back Window Glass
Back Window Glass Moulding / Trim
Front Corner Window Glass
Front Door Window Glass
Front Door Window Glass Weatherstrip
Front Door Window Motor
Front Door Window Regulator
Heated Glass Element
Heated Glass Element Relay
Heated Glass Element Switch
Power Window Motor
Power Window Relay
Power Window Switch
Quarter Window Glass
Quarter Window Motor
Rear Defogger
Rear Defogger Relay
Rear Door Window Glass
Rear Door Window Glass Weatherstrip
Rear Door Window Motor
Rear Door Window Regulator
Window Glass
Window Handle
Window Regulator
Window Seal
Window Track
Windows
Windshield
Windshield Moulding / Trim
ROXY39
2001 Grand Am, 126000kms, manual transmission, 2 dr
My power windows just stopped working. I was looking for a fuse for the windows, only found a circuit breaker (in fuse box on passenger side) no fuses. Do I need to replace the circuit breaker - is there a fuse?
Other question my signal lights work on and off - just all of a sudden will be dead and then work teh next time....fuse?? Where would this fuse be? Why would this happen - any suggestions???
CLY
  • 308 POSTS
There is no fuse for the window motors. They are on that curcuit breaker you talked about. I would remove the door panel and check for power and ground at the window motor with a test light while you operate the switch. if you have power and ground the motor is faulty. The window regulator will have to come out to replace the window motor and they are rivited in and can be a real pain in the butt. They also have a spring on them that will have to delt with because you could loose a finger if not careful....
As for the turnsignal deal ya got going on it could be a flasher or the turnsignal switch assembly. It ay be worth just puting a flasher in it becuse the turnsignal switch will probably be exspensive....
Cly
MAGILLA156
I have a 2000 pontiac grand am with 112,000 miles. It runs very good, been well kept, but today two problems occured. One...the driver's side power window stopped working. All other windows work fine...I checked fuses on dash and under hood, but no particular one referred to power windows. Two...The change engine oil light came on the previous oil change right after I changed the oil. I just changed the oil again, the light stays on. Does anyone have an answer for these two issues I'm having with this car?
DANO302
  • 8 POSTS
after you change your oil, you need to reset the change oil light after changing the oil. The instructions are in the owner's manual. In the index, look up "engine oil life system". If you have the same manual as me, directions are on page 6-17. With your ignition key to ON (engine not running), push the RESET button located in the driver's side fuse block. The CHANGE OIL light will start to flash, press and hold the RESET button again. The reset is complete when you hear the chimes and the CHANGE OIL light goes out.
NUMBER1
when i try to put the window up or down i can hear the motor is working it just doesnt move
HMAC300
  • 48,601 POSTS
if you can hear the motor working it's agood possiblility that the cable that makes teh window go up and down is broken. it is replaced as an assembly motor and regulator
NUMBER1
is it diffecult to change and are their clips or sonething that may be broken
HMAC300
  • 48,601 POSTS
the door panel has to be takenoff. being a mechanic it's not that hard to do. you have to unbolt teh window from the regulator and rebolt everything in. there are plastic clips on the door panel that may break but most of the time they don't and it can be done fairly easily.
DIANA32180
how easy or hard is it to replace broken windows front and rear side in a 2002 grand am? also how hard would it be if i went to a do it urself junk yard to take the windows out of a car are they easily removed?
Jul 14, 2020 at 5:35 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
The hardest part of the job is cleaning up all that broken glass and removing broken glass from the window channel.I would get the windows from the junk yard if i was you.There easy enough to change.
NUMBER1
i am thinking of buying this car and the guy said the clips were broken and that its an easy fix but im not sure
IMPALASS
  • 3,112 POSTS
Is the window not working? Or is the switch not working? Or you select the switch and you can hear the motor turning but the window isn't moving.?
NUMBER1
the motor is working and all windows work but the driver window
they all work, but the drivers????
roy
IMPALASS
  • 3,112 POSTS
I have attached a couple of things for you. The clips shouldn’t be that bad to change. I have attached a pic of them and the regulator. Also, a video on how to change. I would first take apart to see what you need as you can drive with the door panel off. That way you are sure of the problem. Also, I would purchase a couple of door panel Christmas trees as most of the time they brake when you are taking the door panel off. http://www.youtube.com/watch?v=RFJS6qBaQx8
IMPALASS
  • 3,112 POSTS
Here is two other things for you
RICHLYN G
Hi, both my driver and passenger side windows fell into the door. My ****** took both doors off and put sticks in them to hold the windows up as termporary fix. How can I actually fix this so it works properly and for how much ?
SATURNTECH9
  • 30,869 POSTS
So were talking about the front windows?What broke the regulators?Are you going ti fix it yourself?
RICHLYN G
Yes the front windows. I'm not sure what broke, thats what I need help with. I need to know what are possibilites of what may have happened. Depending on what is wrong I'm not sure if I can fix it my self. I really want professional help so I know for sure it's correctly done.
