2003 Pontiac Grand Am wiill not start
BIGBOY49
  • 2003 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 75,000 MILES
My car will not start when outside air temp. Is below 50 degrees. Above that it runs fine. I changed crank sensors, map sensor, wires, computer, tune up still will not start please help
Wednesday, November 4th, 2009 AT 9:41 AM
Do below and check what's missing fuel or spark
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Wednesday, November 4th, 2009 AT 10:22 AM
