2002 Pontiac Grand Am crankshaft pulley
2002 PONTIAC GRAND AM
THE ROCK
Engine Mechanical problem
2002 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic
One of my pulleys has worked it's way loose. I believe it is the crankshaft pulley, because I have no power steering, my alternator is not charging properly. etc.
The belt is on every pulley except this one..how can I gain access to this pulley and put it back on properly?
Thank you for your time.
Mar 17, 2009 at 12:49 PM
BLACKOP555
  • 10,386 POSTS
what pulley is it? very bottom? right? left? top?
to get to it jack up the passanger side of vehicle. remove wheel and then ou can remove the wheel well to make it easier to get to it. if you want to attempt it by reachign down throgh the top i dont suggest it, its a pain in the ass.
Mar 17, 2009 at 3:19 PM
