With key on you have power and radio, lights if so
try and move the shifter to N
start should not freeze unless it had water in it
you can try and lightly tap on the starter as a helper try to start
if that worked I would have the start replaced
if not need to do some testing
1st check fuses
using a test light or a voltmeter
check if have battery power at the big wire at the starter
you should have power all the time
have a helper hold the ignition in the start position as you check the small wire at the starter for battery power
if have power at them both and still no start starter no good and need to be replaced
good luck
Monday, February 1st, 2010 AT 4:59 PM
