Hello, I'm not sure which 30 amp fuse? My info shows two fans, 30 amp fuse on the ground circuit, right fan. 30 amp fuse voltage circuit, left fan. I'd take the fan connector loose, use jumper wires from the battery for voltage and ground, use an inlne fuse. If the fuse still blows, replace the fan.
SPONSORED LINKS
Thursday, August 20th, 2009 AT 10:23 AM
