Need more information is it electronic or manual/belt driven. If its manual the clutch may be bad on it. If electric test for juice at the motor if not check relays and wires running to it also coolant temp sensor and coolant temp sending unit. If there is juice at the motor then the electronic motor in it is bad.
SPONSORED LINKS
Monday, October 29th, 2007 AT 7:19 PM
