2002 Pontiac Grand Am
YULEISKA
  • 2002 PONTIAC GRAND AM
  • 6 CYL
  • 4WD
  • 117,000 MILES
I have a 2002 Pontiac Grand am SE1. Lately its been doing strange things. One is that the car is really loud. When you turn it on it sounds like an airplane. It vibrates a little especially when your at a ligh and if you go over 50 miles per hour it shakes. Its been using up a lot of gas too. Im concerned and I dont want to go into a garage without having some idea of whats wronge. They see a female and automatically try to take advantage. I have to be honest I know nothing about cars. Its had an oil change, and a cleaning of the gas line. Can you give me an idea of what it could be
Tuesday, August 10th, 2010 AT 11:44 AM
  • 109,896 POSTS
Has the check engine light come on? Also, do you know how to check for vacuum leaks? Finally, when was the last tune up?
Tuesday, August 10th, 2010 AT 11:47 PM
YULEISKA
Thanks for your reply. No the engine light has not come on. I have no idea how to check for vacuum leaks and the last tune up was in November of 09
Wednesday, August 11th, 2010 AT 7:04 AM
  • 109,896 POSTS
There are hoses on the engine that carry vacuum from the engine to components. Check for disconnected ones, dry rotted, or damaged ones.
Also, you mentioned the engine sounds loud. Does it sounds like an exhaust leak or something under the hood?
Wednesday, August 11th, 2010 AT 9:26 PM
