2002 Pontiac Grand Am
JULIE WEADGE
  • 2002 PONTIAC GRAND AM
Engine Mechanical problem
2002 Pontiac Grand Am Automatic
we replaced the fuel filter fuel pump and checked fuses its getting gas but wont start
Saturday, December 27th, 2008 AT 12:07 PM
BRIAN 1
  • 1,030 POSTS
Are you getting spark?Any security codes?Whats the fuel pressure at?
Saturday, December 27th, 2008 AT 12:56 PM
MITCHGENDRON
Have you tried the passlock solution, if your security light is on you will need to put the key to the ON position for at least 10 minutes, then turn it off completly, then try to start it, if its due to the passlock " security" then this should work for u.
If that dont work, check for spark, if it's a 2.2 ecotec, no spark then its probly your ignition control modual, about 140 bucks canadian.
If u got spark, the youll need to check fuel pressure, you may need special tools for this
good luck
Saturday, December 27th, 2008 AT 11:08 PM
