2000 Pontiac Grand Am hesitation
CARLSONCALLIE
  • 2000 PONTIAC GRAND AM
Engine Performance problem
2000 Pontiac Grand Am 4 cyl Front Wheel Drive 150000 miles
I have a 2000 grand am 2.4L--the problem I am having is it has a hesitation almost every time you take off from a stop other than that it runs fine I have changed spark plugs plug boot fuel filter the injectors all seem to be working fine the computer said there was a cylinder 4 misfire so I tried to switch the coils around made no diffrence--there is no check engine lights or anything of that nature on air filter is clean I tried some sea foam made no difference--what could the problem be anyone have any ideas it would be greatly appreciated
Wednesday, August 25th, 2010 AT 10:08 PM
Lack of acceleration, chugging, hesitating, bogging, misfiring etc. Could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Thursday, August 26th, 2010 AT 10:13 PM
