Yours don't have one
This crankcase ventilation system does not use a PCV valve. The system uses a separator to vent the engine and separate the vapour from the oil. Returning the oil to the crankcase and the vapour to the engine to be reburned. A plugged oil/air separator or hose may cause:
Oil leaks due to high crankcase pressure.
Sludge in the engine due to inadequate separating of crankcase vapors.
SPONSORED LINKS
Wednesday, September 8th, 2010 AT 5:15 PM
