HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Grand Am
Drivetrain
Transfer Case
SPONSORED LINKS
1996 Pontiac Grand Am
JACOB2018
MEMBER
1996 PONTIAC GRAND AM
1996 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic
wat do I do if there is water in cylander 2
Wednesday, August 5th, 2009 AT 2:34 AM
MECHANIC
Its either a blown headgasket cracked head or block could also be an intake manifold leak
You could try getting it block and pressure tested to find out where exactly is it leaking at.
SPONSORED LINKS
Wednesday, August 5th, 2009 AT 3:24 AM
JACOB2018
MEMBER
The seal is bad but idk if I should just buy a gasget and it will be ok but will the water just dry
Wednesday, August 5th, 2009 AT 3:30 AM
MECHANIC
You can try replacing the headgasket-when you open it up you can wiped off the water then go from there
Wednesday, August 5th, 2009 AT 3:55 AM
Please
login
or
register
to post a reply.
Related Transfer Case Content
Engine Problem 1996 Pontiac Grand Am 4 Cyl Wheel Drive Type Unknown Lots Miles Cylinder Misfire.I Tuned Car Up. Running Bad
Asked by
sugar02
1 ANSWER
1996
PONTIAC GRAND AM
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
2000 Pontiac Grand Am
Engine Mechanical Problem 2000 Pontiac Grand Am 4 Cyl Front Wheel Drive Automatic I Recently Bought A 2000 Pontiac Grand Am That Is A...
Asked by
closota
1 ANSWER
2000
PONTIAC GRAND AM
1998 Pontiac Grand Am Schematics, Wireing Diagram For...
Computer Problem 1998 Pontiac Grand Am 4 Cyl Front Wheel Drive Automatic Is It Possible I Can Recieve The Wireing Schematics For The...
Asked by
susanharrell
1998
PONTIAC GRAND AM
Shaking
I Have A 1999 Pontiac Grand Am Se, 3.4 Engine, Front Wheel Drive, 81,000 Miles And Every Time I Reach Speeds Of 72 Or Above I Get Shaking...
Asked by
JESSEM
1 ANSWER
PONTIAC GRAND AM
2003 Pontiac Grand Am
2003 Pontiac Grand Am 4 Cyl Front Wheel Drive Automatic I Have P1441 Code Which Is "evap System Flow During Non Purge". Where Do I...
Asked by
bunch
1 ANSWER
2003
PONTIAC GRAND AM
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
How to Service a Manual Transmission - EASY!
Bearing Hub Replacement
Online car repair manuals
