2000 Pontiac Grand Am Engine cuts off
KAY PROSSER
  • 2000 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 93,000 MILES
The car runs fine while cold, but once it warms up it will cut off going down the road. Which is dangerous running 55 mph. It does not code. We have checked fuel pressure which shows fine. Changed fuel filters and even put on a new pmd. But it still cuts off. When it cuts off it has to cool a while before it will crank back up. Please help.
Friday, June 27th, 2008 AT 11:33 AM
BMRFIXIT
  • 19,053 POSTS
After it stall you checked the fuel and you had pressure ?
did you check for spark ?
after it stall on you need to check for fuel and for spark
check crank sensor and module
Have an automotive repair question!
Sign up and ask your automotive question !
https://www.2carpros.com/affiliate/uid/bmrfixit_1_tlid_
Sunday, June 29th, 2008 AT 6:15 AM
