Hi crystal. Please don, t cry. We will help you through the whole process. Take your car to the shop tell them it is leaking coolant and that you want it pressure tested.
The smoke you seen from under the hood is good. This means you have coolant leaking near the sight of the smoke. This means it is most likely a water pump or even a hose.
But remember you have control if you are not completely understanding what the tech is telling you or you have doubts you don, t have to deceide then. WRITE US we will tell you if you are being ripped off or not. Good luck billymac
Thursday, June 18th, 2009 AT 7:50 PM
