1999 Pontiac Grand Am Trouble starting
FEPAULINO
  • 1999 PONTIAC GRAND AM
Engine Performance problem
1999 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic >130K miles
After the car sits over an extended period of time (overnight/commuter parking) it will not start. The starter turns the engine over but it will not run. Also happens after it is driven and you try to start it after turning it off for several minutes. Occasionally when starting it, the engine stumbles and won't continue running without flicking the accelerator. On other times the engine starts fine but stays at around 2K rpm even after warming up.
Had it towed twice to the mechanic and it has started flawlessly. They held it over night on both occasions and again it started fine according to them.
The battery is new as are the air and fuel filter. The plugs were chaged 2 mos. Ago and the wires 6 months ago. According to the mechaic the fuel pres. Is at 55psi. Once running, it runs fine with no stumbling or hesitation. No codes or check engine light.
Sunday, December 27th, 2009 AT 8:58 AM
Check your charging system. If ok, check and test the Idle Air Control Valve and the EGR Valve.
Sunday, December 27th, 2009 AT 7:38 PM
FEPAULINO
  • 5 POSTS
Thank you Ras. The battery was replaced due to age but the charging system is OK according to the machanic. As for the Idle air control valve and EGR valve I will look for a testing procedure and check those.
THANKS.
Monday, December 28th, 2009 AT 8:20 AM
FEPAULINO
  • 5 POSTS
Changed the IAC valve and all seems OK. Thank you for your help Ras.
Monday, January 4th, 2010 AT 8:24 PM
