I have a 1999 Pontiac Grand Am with almost 130000 miles that cuts off in the middle of driving. I turn the ignition off and back on and it starts right up. What can this be
Friday, April 25th, 2008 AT 6:56 AM
2CARPRO JACK
MECHANIC
Could be an ignition module, crank sensor, cam sensor. Almost any sensor can cause that. Is the check engine light on? I would start by having it scanned (PCM) for trouble codes, this may give us a direction to start in
SPONSORED LINKS
Friday, April 25th, 2008 AT 7:43 AM
LRAKELLEY
MEMBER
None of the lights on the dash board come on. I do know that the RPM does not stay reved, I think that is how you say it: It seems like it wants to stall or stay below 1.
Friday, April 25th, 2008 AT 8:32 AM
2CARPRO JACK
MECHANIC
Have it scanned for codes. Get back with the exact code/codes, Also have a fuel pressure test done
