Probably the most likely cause is a spark-related misfire that allowed unburned gas to accumulate in the exhaust system where it finally ignited with a "bang". On 1996 and newer models, the Engine Computer will detect which cylinder is misfiring and it will set a diagnostic fault code identifying that cylinder. That type of fault code will cause the Check Engine light to turn on too. The people at many auto parts stores will read those codes for you for free. Record the number(s) so we can see what they mean.
Oct 20, 2016 at 1:40 PM
