Make sure that the temp sensors, intake air and coolant, are reading properly.. If not the would run you to lean in the cold causing a misfire. Also make sure that there are no vacuum leaks, which again would lean it out Otherwise, it is most likely a crank, distributer, or fuel delivery problem including the maf and other sensors.
SPONSORED LINKS
Thursday, December 14th, 2006 AT 4:04 PM
