1998 Pontiac Grand Am Engine keep stalling in real hot weat
CYBERCHIP
  • 1998 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 120,000 MILES
Problem begins after the car has warmed up completely. Engine runs fairly well at high speed, stalls in stop and start traffic or when having to slow down but not stop. Engine usually restarts after it stalls, but, after stalling numerous times, does not readily restart. Sometimes will cut-out while running, or significantly lose power. This happens only when outside temperatures are over 85-90 degrees. This does not always happen in hot weather, and has never happened in cooler temperatures. This has been a problem since the car was new, but recently the problem has gotten much worse. Because it happened so infrequently in the past, no one has ever been able to diagnose the problem.
Monday, April 27th, 2009 AT 2:06 PM
  • 109,936 POSTS
Has the check engine light ever come on? Has anyone ever tested fuel pump pressure?
Monday, April 27th, 2009 AT 8:56 PM
CYBERCHIP
No, the check engine light has never come on. The fuel pump pressure has been check, and appears to be normal.
Thank you so much for your help!
Chip
Monday, April 27th, 2009 AT 9:55 PM
  • 109,936 POSTS
Make sure there are no vacuum leaks and the catylatic converter isn't plugging.
Monday, April 27th, 2009 AT 11:11 PM
CYBERCHIP
A check of the vacuum system did not show any deficiency with vacuum. The exhaust system does not show any severe back pressure indicating plugging of the catalytic converter. I realize this problem makes no sense. The car runs great then outside temperature is below 85-90 degrees. It is only in very hot weather that there is a problem.
Thank you,
Chip
Tuesday, April 28th, 2009 AT 2:24 PM
  • 109,936 POSTS
When it gets above that temp, check fuel pump pressure. The pump may be failing.
Tuesday, April 28th, 2009 AT 8:12 PM
CYBERCHIP
I was able to get that fuel pump pressure reading. It is between 43-45 PSI. I also checked for DTC codes with my new scanner and everything with the scan passed. No trouble codes were reported.
Thank you,
Chip
Friday, May 1st, 2009 AT 11:32 PM
  • 109,936 POSTS
It sounds like an ignition module.
Saturday, May 2nd, 2009 AT 1:11 PM
