Hello, the battery has a full charge, cables ok? If the starter won't even crank, did you try cranking in neutral? With the key in the crank position, can you tell if there is a load on the starter? One way might be to watch your dome lite when you crank it, if the lite stays bright, you may have an open circuit. The purple wire at the starter solenoid should be hot with the key in the crank position.
SPONSORED LINKS
Friday, July 24th, 2009 AT 8:56 AM
