Engine Performance problem
1998 Pontiac Grand Am 4 cyl Front Wheel Drive Manual
car starts then dies you can restart but dies fast
Wednesday, February 10th, 2010 AT 10:33 AM
JDL
MECHANIC
Hi, how long since a tune-up? Use a gage and check fuel pressure. There are many possibilities, If you open the throttle just a little, will it stay running? Check tps--egr--vacuum leaks. Can you check for codes?
SPONSORED LINKS
Wednesday, February 10th, 2010 AT 11:17 AM
JEREMIAH HATTON
MEMBER
Thank you for the help found out the thef sys was activated reprogram the key fix for now thank you agin.
