1998 Pontiac Grand Am could broken seal on coolant resevoir
JATWOOD32
  • 1998 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 140,000 MILES
My car is overheating and lossing coolant every other day and the only thing I can find is broken seal on coolant resevoir cap- could that be the problem?
Thursday, May 22nd, 2008 AT 8:13 AM
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat, Pressure test the Rad. Cap, Clogged radiator, Fan clutch, Radiator electrical fan, collaspe hoses, water pump
Thursday, May 22nd, 2008 AT 8:40 AM
