1998 Pontiac Grand Am Temperature Sensor
BUDHOCKEY26
  • 1998 PONTIAC GRAND AM
Engine Cooling problem
1998 Pontiac Grand Am 6 cyl Two Wheel Drive Automatic
My friends car over heated the other day, the coolant exploded everywhere. I couldnt find anything wrong with it, so I thought it had to be the temperature sensor. I have no idea where it is located, or if something else could cause it to over heat. They told me the temp was about 260 when it happened and it took awhile for this to happen.
Wednesday, April 7th, 2010 AT 1:47 PM
  • 109,709 POSTS
THe temp sensor won't cause it to overheat. When you say it exploded, do you mean a radiator hose blew? As far as the overheating, it could be a thermostat, plugged radiator, bad cooling fan motor. The cheapest thing to try is the thermostat. Most likely it is bad. As far as the sensor, of the gauge in the car was reading 260 F, then the temp sensor was working.
Tuesday, April 20th, 2010 AT 10:52 PM
