Maybe...
plan on doing a lot of homework first. Things that will likley have to be changed are pcm and maybe bcm. The wiring harness will probably not work and need modification. You may get down to the end as one fella did after he swapped out a saturn engine with another to find out there was one sensor that required a two wire connector that his harness did not have and the particular sensor was not interchangeable with one that could fit a two wire one.
Either get a reman 2.4 or used one and drive it or sell it. You may end up owning an expensive
otherwise.
SPONSORED LINKS
Sunday, March 30th, 2008 AT 10:23 AM
