1996 Pontiac Grand Am gas pump problem
DIAZ101
  • 1996 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 99,000 MILES
How would you know if your gas pump is not working?
Monday, December 1st, 2008 AT 7:20 AM
MMPRINCE4000
  • 8,548 POSTS
If you mean fuel pump, the engine would not start. On some cars you can hear the pump energize when you turn the key to "on" for a few seconds, then a "click" which is the relay and then pump would turn off untill you start the engine.
The only real way to be sure is to have the fuel pressure tested with a mechanical gauge. If no pressure, then pump, fuse, relay or wiring.
Monday, December 1st, 2008 AT 8:26 AM
