You could swap any engine that came in the 95 GA.
Problems would be wiring harness, ECM, motor mounts, trans. Mounts, trans connection to engine, CV shafts. It would be a big job.
If you swap outside the box, that is, any engine that was NOT offered in the 95, then you run into fabrication issues.
SPONSORED LINKS
Saturday, November 28th, 2009 AT 7:55 AM
