1994 Pontiac Grand Am
RONNIMERICHTER
  • 1994 PONTIAC GRAND AM
  • 4 CYL
  • 220,000 MILES
I have a 1994 grand am with a quad motor. It is running ruff. Feels like it is running off 3 cyl. Changed out spark plugs. And still have the problem.
Sunday, August 15th, 2010 AT 8:30 PM
RONNIMERICHTER
What would you start with first. And what is the most common solution to this problem?
Sunday, August 15th, 2010 AT 9:04 PM
Start with the oxygen sensor and idle air control valve and then throttle positon sensor-I'm not aware of any common problems with this vehicle-there's numerous things that can cause your problem-could be compression/fuel and spark everything has to come together for it to run smooth-its hard to say where its coming from-extensive diagnostics has to be performed.
Mileage at 220K's miles there's wear and tear
Sunday, August 15th, 2010 AT 9:22 PM
