1993 Pontiac Grand Am Water Pump
AWITTE91
  • 1993 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 95,800 MILES
How do I replace the water pump on my 1993 Pontiac Grand Am Quad 4?
A step-by-step would be great!
Thanks for your help
Wednesday, December 2nd, 2009 AT 9:51 PM
BMRFIXIT
  • 19,053 POSTS
Water pump is driven by timing chain idler sprocket and is mounted on rear of timing chain housing.
Disconnect negative battery cable.
Drain cooling system.
Disconnect oxygen sensor, and remove exhaust heat shields.
Remove exhaust manifold.
Disconnect outlet pipe from water pump cover, oil pan and transaxle.
Remove water pump nuts.
Remove water pump and cover assembly.
Remove water pump cover bolts.
Thursday, December 3rd, 2009 AT 5:58 AM
