1992 Pontiac Grand Am
SHARON ZDOLSKI
  • 1992 PONTIAC GRAND AM
1992 Pontiac Grand Am 6 cyl Two Wheel Drive Manual
my car turns over but wont start-it was running good until we replaced the water pump
Sunday, February 15th, 2009 AT 11:54 AM
JDL
  • 16,098 POSTS
I'm not sure of the litre size of your engine? Your obd1, can you check codes?
Can you do some basic tests, have a helper crank it, while you check for spark at the plugs. Are the plugs dry, do they smell like gas?
I didn't see anything about changing the water pump that would keep the vehicle from starting.
Sunday, February 15th, 2009 AT 1:45 PM
SHARON ZDOLSKI
  • 5 POSTS
The grand am is a 3.3 no spark and the trouble code is 12
Monday, February 16th, 2009 AT 8:39 AM
JDL
  • 16,098 POSTS
The code 12 is diagnostic mode. With the engine cranking, if you have no spark at the plugs and no injector pulse, check the crank sensor. Take the connector loose, maybe something got wet, dry it off. You can check for ref voltage and ground, two signal circuits for a dual crank sensor.
Monday, February 16th, 2009 AT 10:56 AM
