1993 Pontiac Grand Am No Parking Lights
Suggested Repair
Check the underhood power center fuses and relays, power at the headlight switch, and power from the ignition switch in the run position. The slow window likely has a failing motor; do not replace the steering column first.
Conversation Summary
The owner of a 1993 Pontiac Grand Am reports working headlights, turn signals, and brake lights, but no parking or running lights, fog lights, dash lights, or interior lights. The blower appears inoperative and the car only warms after long idling. Front power windows are slow or inoperative, and the fuses were already checked. Family members suggested replacing the steering column or nearby relays. The expert said the slow window sounds like a failing motor and advised checking underhood power-center fuses and relays, power at the headlight switch, and ignition-switch output in run.
