Well, I plan on keepin the car untill I can save up for a newer one but I think its coming through the spark plug holes if it is a head gasket. Are you taking about the gasket under the cover if so im looking at the chilton book and it doesnt look to hard to replace. She is old and has a lot of sludge im using 10w 30. I live in north dakota so that works. Im using castrol gtx oil sludge protection but the book says not to use synthetic oils in new or old cars. Do you mean the rocker arm gasket? I found the head gasket in the book that wouldnt be cheap but I was looking up symptoms I do get a pop in the muffler, antifrieze smell from heater, not to much white smoke, no coolant coming through spark plugs, not sure about bubbles in coolant. Does seal steel work. Again thank you for any advice
SPONSORED LINKS
Saturday, September 25th, 2010 AT 12:46 AM
