overheating
TOM BRENTESON
I have a 1987 Pont. trans Am gta it has a 5.7tpi motor with 165000 miles. My problem is the car is overheating and when I try to add coolant the fluid is shooting out of the radiator. I know it sounds like a blown headgasket but could it be something else.I don't see or smell any coolant coming from my exhaust also I never noticed that it was loosing fluid internally just what came out of the overflow.
Nov 3, 2007 at 6:12 AM
BLACKOP555
  • 10,386 POSTS
really sounds like a bad headgasket leak to me, to test it do a compression test. if all checks out then it is not the headgasket and you should then chec
Nov 3, 2007 at 7:42 AM
