1997 Pontiac Firebird High RPM Stall
JACKDON
The car is 97 Pontiac firebird V6 3.8 ll with 120,000 mi.
The problem is the car will not run above 2000 rpm's. It sounds like it just smothers out. I have replaced the following parts:
fuel pump, fuel filter,fuel regulator,throttle positioner,MAS,. the code reader shows no more problems. do you have any answers?
Mar 18, 2007 at 2:21 PM
PEPPERMRJ
  • 1,158 POSTS
Use a vacuum gauge to check for a plugged cat.
testing for blocked exhaust
"Starting with the engine at idle, slowly increase engine speed to 3,000 RPM, engine vacuum should be equal to or higher than idle vacuum at 3,000 RPM. If vacuum decreases at higher engine RPM's, an excessive exhaust back pressure is probably present.
idle speed reading slowly dropping toward zero indicates exhaust restriction.
excessive backpressure in exhaust then indicated by reading not increasing quickly to about 16 in Hg
when engine speed slowly increased to 2000 rpm.
backpressure also indicated by reading not dropping as quickly when throttle quickly released and remaining 5 inHg higher or more than normal."
If that is not a problem check the map sensor. Be sure the electrical connection is clean and tight. Be sure there is vacuum to the sensor. Check for goo in the vacuum line at the sensor.
Good luck and let us know. :)
Mar 18, 2007 at 3:14 PM
Suggested Repair
Use a vacuum gauge to test for a plugged catalytic converter or excessive exhaust backpressure. If the exhaust is not restricted, inspect the MAP sensor electrical connection, confirm vacuum reaches the sensor, and check the vacuum line for contamination.
Conversation Summary
A 1997 Pontiac Firebird 3.8 with 120,000 miles will not run above 2000 RPM and seems to smother out. The owner replaced the fuel pump, fuel filter, fuel regulator, throttle position sensor, and MAF, and reports no remaining codes. The expert recommends a vacuum-gauge test for a restricted catalytic converter or exhaust, then checking the MAP sensor connection, vacuum supply, and vacuum line.
