1997 pontiac firebird 6 cyl...76,000..fuel gauge won't work..replaced fuel sending unit and gauges..is there anything else to check...PLEASE HELP
Jan 10, 2007 at 8:23 AM
2CARPRO JACK
✓Experienced Mechanic
At the bottom of the main forum page is a link to Mitchell1. Go to wiring diagrams and find th esender wire. Test with an Ohm meter for continuity, there might be a break in the wire
Jan 10, 2007 at 11:27 PM
SERVICE WRITER
Does it always read empty?
Or always read full?
Jan 12, 2007 at 12:35 PM
TRACKER
MEMBER
it always reads 3/4 except when you fill it then it moves toward full a little bit
Jan 14, 2007 at 5:20 AM
SERVICE WRITER
I'm far from a wiring pro, and Jack probably has the right answer, but I have received bad sending units that did that.
